I'm not sure if I can determine my 9" rear ends bearing size without pulling an axle out? I was told that the bolts for the bearing retainer plate (is that the right English term?) are different? Any help plz?
DK832 said:I'm not sure if I can determine my 9" rear ends bearing size without pulling an axle out? I was told that the bolts for the bearing retainer plate (is that the right English term?) are different? Any help plz?
Edbert said:Axles would only affect the inner dimension of a bearing not the outer. Ford only made the two, large and small. Large came only on trucks (E-series/F-series/Bronco) and full-size (Galaxie not Fairlane) vehicles. ALL mustangs had small bearing 9s, of course your rear could have been swapped over the last ~40 years, so there's no subsitute for measuring.
--(Large axle bearing 9-inch housing on left from a '60 T-Bird . Small bearing 9-inch housing on right from a '59 Fairlane).Hope you don't mind! I'm sure I am one of a few thousand who have that bookmarked. Here's the full link http://www.ultrastang.com/Rearinfo.asp?Page_ID=1ultrastang said:I recognize that photo. It's from my website.--(Large axle bearing 9-inch housing on left from a '60 T-Bird . Small bearing 9-inch housing on right from a '59 Fairlane).
Edbert said:Hope you don't mind! I'm sure I am one of a few thousand who have that bookmarked. Here's the full link http://www.ultrastang.com/Rearinfo.asp?Page_ID=1
The caption says the one on the left is from a '57 station wagon.
my car definitely has the original rear axle 7 1/4 that's what I saw in VIN number. I read that there were not many. when I removed the rear axle I saw that it has 24 splines.I'm not sure if I can determine my 9" rear ends bearing size without pulling an axle out? I was told that the bolts for the bearing retainer plate (is that the right English term?) are different? Any help plz?
