What ring goes on top?(shortblock assembly)
chirs said:
Dont forget to stagger the rings!!!!!!!!!! Just did mine awhile back. Damn, i dont remember which one goes where.
i dont know why you are deeply encouraging him to stagger the rings. From what im guessing, you mean have the ring gaps not lined up. it doesnt really matter because the rings turn the whole time the engine is moving, so at one point they line up and thats why 100% of engines burn oil. its only for a split second anyways, he'll be fine, dont worry.
I'm going with Vib on this one and I'm scared. This is gonna be an interesting first start. I don't want to sound like a dick but we're talking about your shortblock here, you can't just **** it up and fix a little something. If you can't even get your rings on correctly, hows the rest of the motor going. What rings are you using and whats your end gap at?
Jeremy
Depending on what rings you have, the chrome outer edges go on top. Yes the rings are very loose on the piston.
I assume you have a book? The "How to rebuild the small block Ford" is a execelant book to have while rebuilding a engine. I have used it everytime I have rebuilt a engine. It helps since I don't rebuild engines all the time.
Good luck. When it starts up, you will be so proud & happy that you did it all yourself.
