Asha'man said:When my car is warm, it usually idles around 600-700. It definitely seems low, I've actually killed the motor by turning the wheel to full lock (high load on the engine, I guess). How do you adjust the idle? I've never thought about it.
Ash
Lx89Stang05 said:you cant cchange the idle its all computer controled
mr_woodster said:um, you can adjust base idle by turing the screw/spring on the throttle body plate. Clockwise raises idle , counter does the oposite. Very simple!
GTPhreak said:Thats not a "idle adjustment" screw. it is simply there as a stop screw.
if you want to adjust the idle "properly" you will have to get a chip or tuner to change it
Pro-Hawk said:Ok I know this may stray some from the topic, but I have to ask anyways. Do they make a super chip for these cars, and does a tunner just reprogram a EEC completely? Like if I had a PJ EEC could I reprogram it for a PE EEC? Aslo if your EEC is a older one with idleing problems could either a super chip or a tunner fix this?
Just exploring options to my idleing problem on my SVO.
Thanks
ka0tyk said:http://www.tweecer.com/
kinda expensive, havent heard and 100% proven facts on how well it performs...
ka0tyk said:that "stop" screw will change your idle, but you need to keep in mind that you need to adjust your TPS back to the correct voltage to properly be at idle...
ie: bumping your idle from 700-900 might make your TPS read over .98 which the computer will think your car is never at idle... you'll get horrible gas mileage and possible surging. also when you play with the idle stop screw you have to reset your computer because the butterfly will be open more, which means at idle your car's IAC will be off...
mr_woodster said:Ive messed with mine frequently, i have set my TPS once, but since have never messed with the tps after tweakin with the "stop screw". I have not noticed surging, idle issues, or poor gas mileage. Have never purposely "reset" the computer, though i have had the batter out atleast once since then. I guess i dont see what the fuss is, i have always done it this way, have seen it done this way for a long long time with no ill effects....
My dad being a mechanic by profession for more years than i have seen on this earth, he does not install a tuner to adjust the idle in the thousands of cars that have come through here, each leaves with no complaints, idle problems or anything else for that matter? what do u think that screw is there for? it was just to "stop" , it wouldnt be adjustable.
Thanks
Now does this basicaly replace the EEC? Like once you plug it in, it takes over and the car runs off of it?
)PRAISE THE LORD! lol, ill take luck when i get it...believe me, 3 heads later for my turbo project, luck seems fleetingka0tyk said:consider yourself lucky to not suffer from the "idle of death"...
<-- has it.
