what sensor is this?
  • Thread starter Thread starter l3lue
  • Start date Start date Jun 2, 2007
L
l3lue
32
  • Jun 2, 2007
Hey guys,
there is a sensor towards the front of my engine that looks like it should have two vacuum hoses connected to it. it's blue and has the part number E32E-9B982-AIA on it..it looks kinda like a T and two vacuum lines should be ran to it...i found it odd because it was just unplugged and with the key on the "on" position it was hot?..any ideas?..
4G-KDMP
935
CA
Jun 2, 2007
  • Jun 2, 2007
5.0?
what year?
HISSIN50
34
129
Jun 2, 2007
  • Jun 2, 2007
Possibly the purge solenoid for the EVAP system.
Post a pic if you got one.
Good luck.
L
l3lue
32
  • Jun 2, 2007
89 5.0 , dont have a pic.
4G-KDMP
935
CA
Jun 2, 2007
  • Jun 2, 2007
on the right or left side of the engine?
L
l3lue
32
  • Jun 3, 2007
passenger side.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 3, 2007
  • Jun 3, 2007
Charcoal canister plumbing - one 3/8" tube from the bottom of the upper manifold to the rubber hose. Rubber hose connects to one side of the canister solenoid valve. Other side of the solenoid valve connects to one side of the canister. The other side of the canister connects to a rubber hose that connects to a line that goes all the way back to the gas tank. There is an electrical connector coming from the passenger side injector harness near #1 injector that plugs into the canister solenoid valve. It's purpose is to vent the gas tank. The solenoid valve opens at cruse to provide some extra fuel.
It does not weigh but a pound or so and helps richen up the cruse mixture. It draws no HP & keeps the car from smelling like gasoline in a closed garage. So with all these good things and no bad ones, why not hook it up & use it?
4G-KDMP
935
CA
Jun 3, 2007
  • Jun 3, 2007
i had no idea that the charcoal box had a sensor that was blu but jrichker and HISSIN50 know way more than i ever will.
i'm trying to learn all i can so and when you get a chance could post a pic of that blu sensor on the charcoal box ?
HISSIN50
34
129
Jun 3, 2007
  • Jun 3, 2007
It's actually a solenoid, not a sensor.
I dont have a pic of a fox solenoid but here's one for a 94-95 (courtesy of Punisher302)
HISSIN50
34
129
Jun 3, 2007
#10
  • Jun 3, 2007
  • #10
EDIT: burp.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
