What shocks/struts to use?
moneypit94
1,723
Macomb, IL
I am saddly still on my stock shocks and struts after 130K miles. I would like to replace them but am not sure what to go with?
I was thinking of just putting a set of Lakewood 70/30's in the front and 50/50 shocks in the back.
Also the verticle shock ( quad shock maybe?) Is it the same size as the other? What should i use to replace it?
Im interested to hear any info on other types and brands of shocks..
rudeone707 said:
what do you mean by 50/50 and 70/30??
From my understanding that refers to the way they give. 50/50 meaning that it takes just as much to push them in as it does to pull them out. Now 70/30 and 90/10's are designed when you take off that your front end lifts really easy and takes more pressure and longer for them to go back down... Hook up better this way because of the transfer in weight and keeping it transfered.
It's a ratio or percentage rebound rate. For example, a 50/50 shock is 50% of its rebound up and 50 percent of its rebound is down. 70/30: 70% rebound up, 30% rebound down. The more of a rebound rate it has upwards, the easier it is going to be to lift the front end.
Joe
