  • 1994 - 1995 Specific Tech
What should i do?(head related)
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Mar 10, 2008
1 of 2 Next Last
9
95mustang_gt
364
Wisconsin
Mar 10, 2008
  • Mar 10, 2008
So my problem is running afr 185 heads on my 306. I got these heads with the planning of having the pistons notch. So the machine shop that was going to do this move the price from $150 to $450,I don’t feel like paying that much. So I was just thinking of selling them or trading for afr 165 heads or twisted wedge heads. So what do you guys think I should do?
Do the pistons have to be notch with twisted wedge heads or afr 165?
btw my intake is the eddy rpm 2
1)trade the heads for afr 165 or twisted wedge heads
2)get the pistons notch
Thanks
jesse
95Vert
1,785
North Mexico (deep south Texas)
Mar 10, 2008
  • Mar 10, 2008
Don't trade the heads, you'll regret it.
Why not notch the pistons yourself? Look up articles and research, research, research.
9
95mustang_gt
364
Wisconsin
Mar 10, 2008
  • Mar 10, 2008
thats what i have been doing for the last two days.Man i got a big headache from reading stuff today.lol
95Vert
1,785
Mar 10, 2008
  • Mar 10, 2008
It'll be worth it when you do it on your own and save $450.
earleys94gt
1,223
Ashley, Ohio
Mar 10, 2008
  • Mar 10, 2008
Don't trade the heads.
For the Twisted Wedge's you do have to notch the pistons too.
Notch the pistons yourself, there are some articles on www.fordmuscle.com if you need some more research.
9
95mustang_gt
364
Wisconsin
Mar 10, 2008
  • Mar 10, 2008
thank you
Should i degree the cam before i notch the pistons?Also can i do this with an adjustable pushrod checker?I only have stock pushrods.
earleys94gt
1,223
Ashley, Ohio
Mar 10, 2008
  • Mar 10, 2008
Degreeing the cam would be nice for some more power, but it's not necessary.
I would use a pushrod length checker to make sure you get the right length. You might get lucky and find out your stock ones are okay, but better safe then sorry.
Are you using pedastal or stud mount rockers?
9
95mustang_gt
364
Wisconsin
Mar 10, 2008
  • Mar 10, 2008
I will be using 1.6 stud mount rockers.
earleys94gt
1,223
Ashley, Ohio
Mar 10, 2008
  • Mar 10, 2008
That's good. This way you can adjust the lash, and have some "freeplay" on the pushrod length.
95Vert
1,785
Mar 11, 2008
#10
  • Mar 11, 2008
  • #10
I COMPLETELY disagree with that comment. What you are doing by not degreeing the cam is leaving power on the table. It'll still run but not to it's full potential.
DDSTANG94
465
FRASER, MICHIGAN
Mar 11, 2008
#11
  • Mar 11, 2008
  • #11
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 11, 2008
#12
  • Mar 11, 2008
  • #12
Degreeing the camshaft will help, IF your camshaft is off to begin with.
When I installed my custom cam a few years ago, it was dead on.
Luck was on my side...
Degreeing more-or-less confirms if you are off or not. If you are off, make the adjustments necessary
Good Luck.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 11, 2008
#13
  • Mar 11, 2008
  • #13
You can get a camshaft with valve timing events so it will clear, but I hate to see an engine being restricted by the radial of the valve on a 20* head being the reason for the camshaft.
You can not get 100% results this way, but it can work nicely if done right.
A 20* valve angled head with a 1.90" intake valve does give more radial clearance.
9
95mustang_gt
364
Wisconsin
Mar 11, 2008
#14
  • Mar 11, 2008
  • #14
The cam i will be using is a custom ed curtis cam with a 526 in/526 ex with 1.6 rockers. Will a summit degree wheel work?
95Vert
1,785
Mar 11, 2008
#15
  • Mar 11, 2008
  • #15
Good Luck.
I think it has more to do with the cam designer than luck. When I got mine, it was also dead nuts on.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 11, 2008
#16
  • Mar 11, 2008
  • #16
I also wouldn't replace the 185's. You could remove the valves and use the heads as a guide to flycut the pistons yourself. You just set the depth you want to notch them, set the clamp, chuck it in a drill, and start cutting away. Check out this thread in 5.0 Tech for more info and a user testimonial about the Isky tool. Here's a link to the tool on Isky's website, too:
http://www.iskycams.com/iskycategory_search.php?sub_category_id=133
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 11, 2008
#17
  • Mar 11, 2008
  • #17
In my conversation with Jay, he told me that noone can guarantee a camshaft that is not off.
That is why he likes to "cam doctor" them
A Summit degree wheel will work. The larger, the better.
I really prefer an AFR 185cc head with some aftermarket pistons, so the valves are not a factor to work around. But, I agree with the other guys - I am not sure you want to get rid of them.
They can be useful now and later.
95Vert
1,785
Mar 12, 2008
#18
  • Mar 12, 2008
  • #18
You're absolutely right. He can't guarantee it and he always recommends for it to be degreed with the dr. but most of his cams are usually dead on, which is awesome!
9
95mustang_gt
364
Wisconsin
Mar 12, 2008
#19
  • Mar 12, 2008
  • #19
which pushrod checker from summit should i get?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Mar 12, 2008
#20
  • Mar 12, 2008
  • #20
Depends on which cylinder head you get. The pushrod length on the TWs are about .500" longer on average.
1 of 2 Next Last
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
R
New heads
  • Robman8028
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2025
gkomo
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
