  • 1994 - 1995 Specific Tech
What should i do?
  • Thread starter Thread starter WhiteStallionGT
  • Start date Start date Sep 4, 2004
WhiteStallionGT
465
Northern VA / VT
Sep 4, 2004
  • Sep 4, 2004
Most of you already know what car I have. Mods, are listed below. The previous owner said he put springs, but my car still seems so big and heavy. What is an affordable way make my car seem a little less luggish and heavy.
thanx
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 4, 2004
  • Sep 4, 2004
Remove unneeded weight.(passengers)
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 4, 2004
  • Sep 4, 2004
Seriously tho advance the timing to 14* and run the highest octane available so it doesn't ping. Under drive pulleys are pretty cheap new just under $100 aluminum. oh yea GEARS are cheap but the install is around $300 tho
JJ95GTID
1,141
Phoenix, AZ
Sep 4, 2004
  • Sep 4, 2004
Gears will pep your car right up. By putting in a lower gear (higher numerically) your engine will be able to move the mass of the Mustang easier. You may actually pick up some milage per gallon too. That is if you can keep your foot out of the throttle.
WhiteStallionGT
465
Northern VA / VT
Sep 4, 2004
  • Sep 4, 2004
I'm car illiterate and i have no clue wat you said, lol
JJ95GTID
1,141
Phoenix, AZ
Sep 4, 2004
  • Sep 4, 2004
Now is a good time to learn. The 5.0L is a good engine to learn to tune. By advancing ignition timing you can gain some noticible horsepower. And, it is a free upgrade. The next cheapest and noticable horsepower increase would be underdrive pulley's. You can do this yourself with a socket set on a weekend. But, like I mentioned before, get the gears. You won't want to do it yourself. But you stated that you wanted something that would rid your car of its sluggish performance and that means gears.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Sep 4, 2004
  • Sep 4, 2004
You'll learn a LOT if you just browse this website
KingDiamond
637
Chicago, IL
Sep 4, 2004
  • Sep 4, 2004
Underdrive pullies are nice but there's a trade-off because your engine will run hotter and your alternator will make less power at idle.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 4, 2004
  • Sep 4, 2004
Read this write up it's pretty much how it's done. If you have any q's just use the search function if that doesn't yeild the anwswer your looking for then just ask. ADVANCEING TIMING
Gt1995
127
Tampa
Sep 4, 2004
#10
  • Sep 4, 2004
  • #10
3.73 rear gears , their only like $180
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 4, 2004
#11
  • Sep 4, 2004
  • #11
They can be had for $135 from gefracing.com but the install is around $300 and he's looking for cheap mods.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 4, 2004
#12
  • Sep 4, 2004
  • #12
Gt1995 hows the weather in your area. If pretty calm down here where i'm at.
R
rudeone707
1,829
Fairfield, Ca
Sep 4, 2004
#13
  • Sep 4, 2004
  • #13
he can just throw in a cooler tstat and he should be fine. I have no cooling problems whatsoever at idle.
Black95GTS
1,644
Marlborough, MA
Sep 4, 2004
#14
  • Sep 4, 2004
  • #14
2 foot, triple stack, erector style wing. With the downforce generated your handling will improve immensely. Make sure to get 6 stickers of the company that made the wing and place them on your windshield, back glass, each side window and above the front wheel wells.
donjohn
1,757
Irvine - Southern California
Sep 4, 2004
#15
  • Sep 4, 2004
  • #15
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 4, 2004
#16
  • Sep 4, 2004
  • #16
That's funny.
WhiteStallionGT
465
Northern VA / VT
Sep 4, 2004
#17
  • Sep 4, 2004
  • #17
Other than Black95GTS, you guys are real helpful, thanx.
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
  • Mindseye007
  • Aug 16, 2026
Mindseye007
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
