What Should I Do?
projectfiveo
347
On my 90 gt i have 160,000 miles and here is everything done to the car since ive had it:
BBK 70mm Throttle Body & Spacer
King Cobra Clutch
C&L Power Pipe
Rebuilt T-5 Tranny
C&L 76mm Mass Air Meter
Rebuilt Trac-Loc
K&N Air Filter
4.10 Gear
Aluminum Under Drive Pulleys
Front Sway Bar Removed
Smog Removed
14* Timing
Shorty Headers
MSD Cap & Rotor Kit
X-Pipe
MSD Coil
Flowmasters
Ford Racing 9mm Wires
B&M Ripper Short Throw Shifter
Heavy Duty Motor Mounts
Aluminum Driveshaft
155 lph Fuel Pump
Eibach Progressive Lowering Springs
Tokico 5-way Adjustable Struts/Shocks
well im getting $3,000.00 for christmas to put into the motor what should i do??
i was thinking about getting the trick flow kit but i already have the cobra r upper and lower here, i guess i could just sell it...but anyway whats the chances of me getting 350hp with 3,000 to the motor?
AFR 165 heads ($1,300), custom cam ($375), gaskets ($150), 24lb injectors ($220), new sample tube for C&L ($????), long tube headers and x-pipe (we'll say $470), and electric fan ($210). That's around $2700-$2800...leaves some many to have some port matching done to your intake-to-head. Not the only route you can go though....SO MANY different options :) The above would be 350 CRANK horsepower no prob..prob around 300 at the wheels.
This all assuming your shortblock is in good shape, if not I would use the money to build a stroker shortblock.
