what should my FUEL PRESSURE be at WOT?
Netrave
84
Florida
hey im curious what to set my FPR at...
I have a basically stock 5.0 with a Vortech A-Trim blower - 8lbs of boost... 24lb injectors, Holley FPR, 190LPH Fuel Pump...
i have it set to 40 right now.. is that too rich?
when i get on my car at like 4500RPMs it feels like kinda a miss... not like detonation but like it bogs 1 cylinder for a sec... but happens a few times...
and i think my plugs are gapped to 32...
any input on my setup???
I'd retitle your thread and try and get the supercharged guys in to help you. What's the rest of the set up besides the booster and injectors? Are you running any kind of fmu? If not, it wouldn't surprise me if you're outrunning the 24's at stock pressure.
i have an FMU calibrated for 24lb injectors, and i have a 75mm mass air calibrated for 24lb injectors so its not a GHETTO setup like you are thinking.
I wasn't making any judgements about your setup -- I asked the questions because you didn't include all the pertinent information in your original post. As I said before, I think you need to specifically target your thread to the supercharged crowd. They probably have the answers you're looking for. If it were mine and I was wondering about my a/f ratio, I'd either take it to a dyno with a wideband and find out what the mixture is; or install the proper sensor and put in an a/f ratio monitor. Those are the only way to be certain - every other approach is pretty much guessing.
