I ditched the smog pump and replaced the A/C with a delete pulley. Everything else is stock on my 91 lx. I know this has to be a fairly common situation, anybody know the belt size I should need?
It depends on what pulleys you are using. Underdrive or standard pulleys. I have underdrive pulleys and I run a 71.5 inch belt. It was trial and error until I hit the right number. Try routing a piece of string or thin rope(twine) around all the pulleys and measure the length.
Dont UD pulleys use the stock belt size anyway? ....I'll probably just do the string thing I just thought it might be hard to get an accurate measurement depending on the position of the belt tensioner.
