What size fuel pump should I get?
Nobody
2,515
Kenmore, WA
I'd like to use a 125 shot dry Nitrous but I know my stock fuel pupmp isn't up to the task. My local shop is telling me not to bother with a 255lph and that a 190lph will be plenty. What confuses me is that they said that a 255lph is no louder/hotter/less reliable/heavier/anything than a 190 and it's only $20 more than the 190lph. So why in the world shouldn't I just get the 255? Is there a disadvatage to a 255 vs. a 190lph?
255 high pressure (GSS340) and be done with it along with a new fuel filter :) Install it yourself, its obvious that shop doesnt realize thata dry kit relies on FP to add extra fuel and you NEED a pump capable of handling that extra load. I got my 255 hi psi for $109 shipped from jd's.
Have to agree, put the big guns in now so you won't have to down the road. I had a 190 LPH in tank from Walboro then went with the 255 LPH high pressure when I put the S-Trim on. Should have went big from the get go, you do the same.
