The car is a 90 GT with stock heads (exhaust bumps removed) cobra intake,65mm tb, 73mm mafs, adj. fuel pres. regulator, 19#injectors, crane 2030 compucam and a full header back exhaust. It also has rest of the usuall bolt ons. The car has an AOD with 4.10 gears in the rear. What size fuel pump do you guys recommend?? 190 lph, 155lph, or 255lph???? Do you think I should upgrade to 24# injectors?? THe car went a best of 13.60 @102 with a 2.18 60ft time.
