  • Mustang Sound & Shine All
What size fuse should an 800W amp use?
  • Thread starter Thread starter AmBo
  • Start date Start date Aug 27, 2004
AmBo
1,027
New Jersey
Aug 27, 2004
  • Aug 27, 2004
Hey all! QUick question. On the way home I blew two 40amp fuses on my power line. I'm running an 800W Kenwood amp. The gain is pretty much 0. It wasnt even cranked, just loud and it blew. Should I be running 80?
DJsZincGT
1,141
WV
Aug 27, 2004
  • Aug 27, 2004
An 80 would be the minimum you should be running. A good rule of thumb to start with is 10 amps/100watts. Sometimes it takes a little more, but that is a good starting point. I have an 80 on my sub amp which just happens to be 800watts and it has never blown a fuse. Knock on wood.
AmBo
1,027
New Jersey
Aug 27, 2004
  • Aug 27, 2004
thx! ill pick up some 80s today!
ChaosStarter
1,637
Metuchen, NJ
Aug 27, 2004
  • Aug 27, 2004
wait, where were the fuses located? if you weren't playing it that loud, there's got to be another reason why they blew. and amped turned down on low volume SHOULD NEVER blow fuses unless something is wrong with the power wire.
DJsZincGT
1,141
WV
Aug 27, 2004
  • Aug 27, 2004
This is correct and I should've stated it, but I only half answered your question. Sorry about that. You may have a bad connection somewhere which will cause you to blow fuses. Check both the power and ground wires. You may have a loose connection or the power wire may be intermittently grounding out. Something else you need to do is look at the blown fuse and see if it's actually blown or if it's melted. If it's melted you are having a voltage problem, which MAY mean that your alternator is not keeping up. In other words your system is pulling more current than your charging system can supply. A fuse will melt under these conditions over time.
larrendeuce
649
Southern NJ
Aug 27, 2004
  • Aug 27, 2004
I had a large sound system in my Bronco. I used a 100amp circuit breaker. That way you don't have to keep replacing fuses.
R
96 V6 Overheated, Heads Resurfaced, Valve Job, No Crank No Start Unless Jumping Ignition Fuse
  • RJohn69
  • May 29, 2024
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2024
RJohn69
R
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • dan50
  • Jul 18, 2026
dan50
M
  • mnky99
  • Sep 5, 2025
mnky99
M
T
Need advice: 93 Cobra audio upgrade with no permanent modifications
  • THNX SVT
  • Feb 18, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 20, 2024
TIGGER
