nickstone302 Member Jan 26, 2010 69 0 6 Maine Sep 21, 2012 #1 Sep 21, 2012 #1 Hi everyone today ill be buying pulleys, maf and injectors for my mustang. It'll be running 8psi ish would 30psi injectors be enough? Sent from my Desire HD using Tapatalk 2
MikeH686 Mine is only two inches though. 10 Year Member Oct 11, 2011 2,843 1,753 184 Waldorf, MD Sep 21, 2012 #2 Sep 21, 2012 #2 Might as well go 42 so your lower on your duty cycle i mean 30s would work but youd be around 80-90 % duty cycle where you couldnt go anymore performance wise with your car its better to go bigger and not have to worry about needing to upgrade again
srtthis the guy doing it does every local racers rear end 15 Year Member Jul 3, 2009 5,129 1,666 204 Maryland Sep 21, 2012 #3 Sep 21, 2012 #3 id go 42's you can get them pretty cheap on lightning forums since they came stock in them
nickstone302 Member Jan 26, 2010 69 0 6 Maine Sep 21, 2012 #4 Sep 21, 2012 #4 Will the lightning ones plug right in Sent from my Desire HD using Tapatalk 2
srtthis the guy doing it does every local racers rear end 15 Year Member Jul 3, 2009 5,129 1,666 204 Maryland Sep 21, 2012 #5 Sep 21, 2012 #5 yes
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,351 21,547 234 Box behind Walmart Sep 21, 2012 #6 Sep 21, 2012 #6 nickstone302 said: Will the lightning ones plug right in Sent from my Desire HD using Tapatalk 2 Click to expand... srtthis said: yes Click to expand... Physically... Yes, they will plug right in. You will NOT however, just start the car and drive away. You will require digital tuning to make these injectors function CORRECTLY regardless of what mass air meter you're running.
nickstone302 Member Jan 26, 2010 69 0 6 Maine Sep 21, 2012 #7 Sep 21, 2012 #7 Would 38s work found a scorching deal on um Sent from my Desire HD using Tapatalk 2
srtthis the guy doing it does every local racers rear end 15 Year Member Jul 3, 2009 5,129 1,666 204 Maryland Sep 21, 2012 #8 Sep 21, 2012 #8 yea what he said.... kinda figured it was a given to know that
srtthis the guy doing it does every local racers rear end 15 Year Member Jul 3, 2009 5,129 1,666 204 Maryland Sep 21, 2012 #9 Sep 21, 2012 #9 nickstone302 said: Would 38s work Sent from my Desire HD using Tapatalk 2 Click to expand... those the blue 03 cobra injectors? if so no.. the plug is wrong
nickstone302 Member Jan 26, 2010 69 0 6 Maine Sep 21, 2012 #10 Sep 21, 2012 #10 No Anderson performance maf and injectors Sent from my Desire HD using Tapatalk 2
