what size tire will fit on the rear
94GTMOOSE
303
jersey shore
i am going to replace two worn tires this month, and two next month. I was do know what tire i want but i do not know what size will fit in the front and rear. i want the tires to be the same size because i want to be able to rotate the tires with out the need of remounting and balancing due to the tire i want is a directional. i have the 96 17inch gt wheels.
I was considering going with a 255/40-17 or a 265/40-17
i am confident that they will fit on the rim, but will they fit in the front of the car as well as the back?
255/45 would be a bit taller than stock...
255/40 would be OK on those wheels IMHO...
Don't know how wide you can go without rubbing to be honest, but unless you want the bulging out at the sides look I am not too sure how much wider you can go with the wheels you have...
