Just like the title asks. I need to buy a torque bit (or whatever it's called) to remove the seat belts. Just want to know what size I need to buy. Thanks.?
jerry beach said:If you have both metric and english allen wrenches, you can use one of them to take them out. They are real tight, but if you find an allen wrench that fits with no slop, you can use it to remove them. I have found that allen wrenches work real well on torx bolts.
88stangmangt said:^^^^^^^^^^^^^^^saves you 15 bucks!!!!!!
89MustangGX said:Do NOT buy a cheap torx bit. Go to Sears and bu ya Crafstman T-50 (not a T-55). Otherwise you will round the bolt out or break the bit off eventually. It's around $7 for the one bit, but worth it. make sure it's the Crafstman one, not one of the cheaper ones.
Kid wita 5oh said:you sure its a 50? i had both and the 50 would work but it wasnt as tight a fit as it should be and the 55 was perfect(i could have just had partially rounded bolts i guess)
