What speedo drive/driven gears do i need ( colors)?
OrangeMustangGt
1,976
Cape Cod, MA
I got some 3:73'z and my speedo is off, i am planning on getting some 17's 03' r's, but anyhow, with my gears, and future tires, what driven/ drive speedo gears do i need? im doing a clutch so i figure why not just do it now?
Manual Transmissions with 8 Tooth Drive Gear
1990-1995 T-5 OEM
1996-1998 T-45 OEM Except Cobra
2.73 Gear Ratio / Yellow 18 Speedo Gear
$9.95
3.08 Gear Ratio / Black 20 Speedo Gear
$9.95
3.27 Gear Ratio / Red 21 Speedo Gear
$9.95
3.55 Gear Ratio / White 23 Speedo Gear
$15.95
3.73 Gear Ratio / White 23 Speedo Gear
$15.95
4.10 Gear Ratio / White 23 Speedo Gear
$15.95
Unless you want to change two gears, one of which is inside the tranny, then get a white 23 tooth drive gear. It will get you within 5%.
The red 26 tooth may be for when you change the driven gear as well, but I don't know. All I know is that I did the 23 tooth one and it's on and I'm happy with it for $15 and 5 minutes. Hope this helps.
