What Stores Miles
streetslayer
My gauge cluster needs replaced and Iv found a used one but didn't know if I should get one with close to same miles. I know some cars the cluster its self stores the miles and others it doesn't.
There's a daughter board that can be transplanted between old/new. This will also help with PATS.
Also consider sending the unit out to United Radio as they are very good at repair/replacing clusters. May have to find a dealer. http://www.unitedradio.com/
However here's some information may help you fix the one that you have.
Cluster PC foil trace repair. How to fix intermittent cluster foil trace repair 1999-2004.
http://www.allfordmustangs.com/forums/v6-tech/304608-my-odometer-goes-off.html#2657361
