what t56 will work with my application
Hope this isn't too much information.
Centered a Viper T56 behind a Ford T5 blow proof bellhusing, which has more surface area to mate the tranny behind that a stock T5 bell. Mated a Ford bronze pilot bushing and a standard Mopar pilot bearing. A Spec stage 3 clutch for Ford TKO already came 26 spline and matched the Viper T56. Also used a Foxbody double hump tranny crossmember, modded for exhaust clearance. Since I used the T5 bell I was able to keep the cable clutch setup from the T5 I had. Whatever T56 you use you will need a bellhousing with correct depth for your input shaft and a a slip yoke to match. A factory Viper T56 doesn't have any speedo equipment and the shifter is different from other T56s. The shifter location is about the same as where my T5 shifter was located.
This pic shows the under brace still intact, I did cut the visible portion and widened the clearance to allow theT56 to tuck into the tunnel better. The hump was welded back on about 1.5"-2", and my engine was lowered about 1". Pinion angle at the tranny is about -1 deg.
