What the hell happened to my sound!
foreverdecember
My 460 head unit got jammed and I took it to a local shop today. They said they couldn't fix it without breaking the unit and i needed a new unit, said they see this kind of thing all the time...well I got a kenwood kd 135 or something like that and now my once rich, sweet, sounding system sounds like a f**king am radio...no bass, and if I turn it up it sounds all gargled...what to do folks?
They threw my old unit away. Do I need to get another head unit? This one is 200 watts, is that not powerful enough or something? What aftermarket head units do you recommend? I want it to sound like my 460 used to...better if possible but just getting back to where it was would be fine...help!
This is the only thing I can find that should work, but I can't verify if it'll work for an 03. I read something about the 03 having a different system, but then it was also mentioned that the speaker system is the same from 95-04. Possibly a different harness at the stereo, so the plugs may be different? Might take a little effort in changing wires around? Not sure what's involved, since I eliminated my Mach460 about 4-5 years ago and went with aftermarket components.
sounds like they bypassed the mach amps and plugged the speakers directly to the H/U :shrug: as mentioned above, find yourself an adapter from METRA or Scosche, and sometimes the only way to get something done right is to do it yourself...
The Metra part # for Mach 460 is a 70-5519. Should sell for under $25. If the shop installed this for you, they didn't do something right. It should sound good even with a KDC-13*. I have sold lots of those head units and never had a problem with it. Hope this helps.
Paul
