With a little experimentation, you can sort of get a feel for what it was like by shifting without using the clutch at all. Wind first out to about 2500 rpm, then when you ease off the gas pull it out of first (no clutch), and just apply steady pressure into second. When the gear and engine speeds match, it'll lightly 'clunk' into the next gear. You should be able to do that all the way through the gears. Same is true downshifting - but you have to blip the throttle in neutral and then apply a little force into the next lower gear. When the engine speed is dropping back down from the 'blip', as soon as the engine and gear speeds match, it'll drop into the next lower gear. It works better on higher mileage trannys where the gears/synchros have lots of wear on them.
