What the hell is going on?? MisFires
This is not mustang specific. Having some problems with my F-150 that are driving me batty.
Last week the truck would die and restart when it cooled off. Figured it was the TFI and I would change it this past weekend. Then it started acting real funky Friday. Major loss of power and then it would run normal. Did this cycle for a bit. Then just ended up with a horrible idle. Definitly a misfire, would backfire every so often.
SO far I have changed the TFI, Coil, Wires, Plugs, rotor, and cap and rewired a relay that had a corroded terminal. Started it up and it still has this misfire. Adjusted timing. Still no good.
Did a Compression check 150-145 across the board except #1 which was 135. But I was using a pushin tester though and could not get a good seal. Will check it again with a screw in.
I noticed one of the Cats glowing. Figured maybe it was backing up So I removed it and now the backfires are really bad.
Checked the voltage to the coil and it is 13.4V.
Sorry for the length But What the hell is up?
