  • 1994 - 1995 Specific Tech
What the hells wrong with it now? Knocking AGAIN *vids*
  • Thread starter Thread starter MysteryMachine
  • Start date Start date May 11, 2006
1 of 2 Next Last
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
  • May 11, 2006
Well my car started knocking like a son of a bitch AGAIN today. Been hearing a weird wooshing noise kinda like the metal exhuast leak woosh noise so i thought it was just an exhuast leak. well pulled away from a light and heard a jackhammer thought they were working on a road near by till I kept hearing the sound so I turned down the radio and it was my car. Replaced the lifters and push rods like last year so i kinda don't think its a lifter plus it sounds louder then when they went. And I laid my head on my intake and it sounds like its coming from stright down in the center. Cam maybe?
And to make it all worst my trucks at a dealer caus the CEL's been on since the winter for the Torque converter clutch seloniold/overdrive performance. Car was runnign good and no more snow so I was finially able to get it in. They called yesterday and said the light was on for the TCC/od thing AND an evap issues said theres lines that go to my canister that are cracked and leaking. But the trans thing they had to drop the trans and see what part was actually the problem I guess it could be like 3 different things and she was suppose to call me back today and never did. And We're going camping on the 26 and I was gonna take my car. I knew the car was gonna crap out on my when I got the truck in the shop. People always made fun of me for having so many cars for "back ups" But the back up always breaks down when the other is getting fixed
Anyway heres a couple vids you car hear the knock. If it comes to needed to tear it down again I think i'm gonna park it till i get the cash for the TFS kit, headers, MAF and INJ's.
Or just sell the bitch lol
http://s5.photobucket.com/albums/y180/mysterymachinegt/?action=view&current=MOV00643.flv
http://s5.photobucket.com/albums/y180/mysterymachinegt/?action=view&current=MOV00642.flv
Guero
2,148
May 11, 2006
  • May 11, 2006
vids dont work!!!!!!!1
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
  • May 11, 2006
FIXED thanks man. BTW hows yours doing?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 11, 2006
  • May 11, 2006
sounds like when i had a bad lifter... hmm... is it possible one of the rockers are hitting the valve cover? i would say pull off the VC's and see if you can push any of the lifters down by pressing on the rockers and look for anything outta place
I
igotyofire
774
Southern California
May 11, 2006
  • May 11, 2006
wow doesn't sound good at all, how many miles do u have, good luck!
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
  • May 11, 2006
doubt it I laid my hand on the vc's if it was hitting I should have felt it
urban96
3,464
Syracuse, NY
May 11, 2006
  • May 11, 2006
the vid from inside almost made me think it was the clutch, how does the pedal feel?
94-302-vert
1,947
NE CT
May 11, 2006
  • May 11, 2006
Wow, when you said it sounded like a jackhammer I was thinking "yeah right"... Are you sure it is internal to the motor? to me is sounds like someone put a card in your spokes...
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
  • May 11, 2006
Urban: From what I remember it seemed fine but I'll check today if i get a chance
Chris would I BS? lol I know a lot of guys on here think I do. And that was controled vids when i really get on it, its horrible. And to answer your question I have no idea.
donkey_punch
565
northern****ingjersey
May 11, 2006
#10
  • May 11, 2006
  • #10
wow IMO it seems like a push rod. i think if a rocker was broken you could feel it on the VC. i also want to say maybe a valve broke loose, but my money is on a broken push rod.
i think we can pretty much say it's in the valvetrain some where from the push rod to the valve.
keep us posted
joe
94-302-vert
1,947
NE CT
May 11, 2006
#11
  • May 11, 2006
  • #11
Does it still run strong? Like does it seem to be down on power like one cylinder isn't working?
What about a compression test? Or maybe pulling the plugs wires one at a time to see if there is a difference on one cylinder... Both easy things to do to at least target where to look...
I really think that if it was a lifter, pushrod, or a rocker you would hear/feel it on the VC.
Zero Signal
2,633
Tucson, AZ
May 11, 2006
#12
  • May 11, 2006
  • #12
You won't necessarily feel it on the VC. Hell, when my rockers were actually hitting the VC, I couldn't really feel it but I could he it with the stethoscope. I recommend picking up a stethoscope from CSK or Sears. It's worth every penny to have one. I could pinpoint pretty much exactly where the rockers were hitting the VC's.
It could be a totally F'd up lifter. I would first pull the VC's and feel around the valve train and remove your rockers and pushrods. If a lifter is shot, you should be able to see some abnormal wear patterns on the pushrod end. If you still find nothing, pull the intake and lifters. It's definitely something in the valvetrain though.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 11, 2006
#13
  • May 11, 2006
  • #13
Or when the lifter went bad last year you could slightyl damaged a cam lobe. And now the lobe is wiped out.
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
#14
  • May 11, 2006
  • #14
Wytstang (sorry man all this stress I forgot your name) Thats what I thought.
Chris seems to run fine just loud as hell
John thats what i was kinda figuring on doing maybe pulling off the VC's and turn the motor by hand and see if anything looks shady
Took it to my garage guy he said its def up top somewhere. And when i said if it comes down to pulling it all i'm buyingthe kit and doing teh heads and cam this time tired of taking it all apart and he said I'd probably be better off.
UPDATE on the Dodge: Torque converter and the pump in the trans is shot. Can't get a new pump till sometime next week. Total will be 2012.21 for fixing everything thats wrong that I listed in the other post and testing,taking the trans apart and putting in back in. Unless the warrenty covers some but they don't cover the trans ****
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
#15
  • May 11, 2006
  • #15
Danny thats it LOL
W
wytstang
Mustang Master
Mar 14, 2004
4,988
May 11, 2006
#16
  • May 11, 2006
  • #16
lol good luck when all the work needed....
WHITE94COBRA
816
HUNTINGTON BEACH
May 11, 2006
#17
  • May 11, 2006
  • #17
My money is on a pushrod and rocker. Thats exactly what mine sounded like when the rocker broke and the pushrod was bangin the VC.
MysteryMachine
1,835
Parkesburg, PA
May 11, 2006
#18
  • May 11, 2006
  • #18
Danny: thanks i need it
Well beings I have nothing else to drive I gotta drive the good ol' '66. Posted some pics http://forums.stangnet.com/showthread.php?p=6137655#post6137655
Well tomorrow is the fire company Banquet so I have off from work so I'll have all day to mess with it untill I have to get ready for that
chromeyllastang
20
#19
  • May 11, 2006
  • #19
i would not drive it,tear it down before more damage is done,good luck.
MysteryMachine
1,835
Parkesburg, PA
May 12, 2006
#20
  • May 12, 2006
  • #20
Well my crazy father thinks If i spend almost 3000 on the kit I should do a full rebuild OR skip the kit and buy a crate motor. Don't know where he thinks I'm getting the cash for all this
1 of 2 Next Last
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
