What to do about minor floor rust....
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
So I started dissasembling my interior because I'm going to dynamat the entire inner body, and when it came time to pull the carpet up, I found this under the passenger seat:
Its not bad enough to warrant a new floor pan, but something needs to be done. What would you suggest?
Also, hurray for no interior!
/no hurray for cell phone camera, though.....
Just knock it off with a wire wheel and repaint it. Not hard at all. I am going thru the same thing. If you dont have a grinder, they make wire wheels for a drill. If no drill (heaven forbid) bust out the ole sandpaper.
You call that rust lol see my sig link...
Anyway just use a grinder wheel (or wire brush - less chance of taking off too much metal) to remove all the surface rust. If you're lucky the rust is only surface rust. I'd use a self etching primer or rust stopper before applying any paint.
Remove the factory sealer, grind, primer and apply new sealer too. Rust is there for a reason, there has to be a small leak somewhere. Mostly it's going to be the factory sealer that came loose...
Snikt89GT said:
Why add all of that weight in the first place?
First, its not "all that weight" it'd be like adding a chick to the car. But that's irrelevent. For me, its about making the interior that much nicer. Being a T-Top car, its draftier and noiser than a trunker or hatchback. So for me its all about reducing rattles, road & wind noise, and increasing sound quality of my stereo. I'm not drag racing, so my ET can suck it.
