What to do now...
JenkinsBS
1,001
Washington
So, I now have my mustang back up and running, mods are in the sig - But im thinking of a few options i can go with right now and having a hard time deciding what i want to do.
Firstly, by no means do i want this car to run 11's at the track (if it even sees the track), I just want something fun for the streets (which it already is), but with a bit more kick. And secondly, i really do not want to have to do any extensive engine work - that part of this project is done for :lol:
So my options are to take out the stock 3.08s or whatever they are from the rear, and replace with some 3.73s - and Pay out the a$$ for labor
Also thinking leaving the 3.08s in the rear, but instead throw in a 5-6 psi vortec supercharger on it, i dont believe there is much tuning afterwords (aside from dyno) - Now i've always heard that turbos are best used in stock applications (motor wise), but is it the same for a SC?
Also thinking of buying some single turbo exhaust kit from somewhere (or someone), that will fit my Borg Warner t-4 i have sitting here waiting, but then also pay someone out the a$$ to fine tune the turbo
I know that the cheaper options are the gears and the SC, i just dont know how much a shop would charge for installing rear end gears
What do you guys think?
K ill be the first to say it. You seem to be on a budget and who isnt? Since you are on a budget then put the gears in yourself. That is what the forum is all about. Even if u cant change a spark plug we got the man power and courtesy to help u learn here. We are one big virtual car club. Do a search on it. You are bound to find a ton of info. Its not a hard job. If u dont search on here to your liking then use google. Now go change some gears man. U wont regret it. :nice:
Hah, i dont know. Ive watched youtube videos of how to change out rear end gears, i dont have a micrometer :rlaugh: Im sure there are other ways to do it, and my budget isnt that low, if the supercharger with the lower gear ratio is nice and streetable, just gotta save for a month or so :D
I know gears are almost a no brainer for budget speed, even to pay someone to do it, but i have a 5 speed and do want to do some freeway driving - i could go with a lower gear ratio, but that isnt HP
Steeda does a gear change for $449 which includes all the parts plus labor. I mention Steeda because they can be a bit pricey but it's done right (got both my 90LX and 94Gt done there). If you don't know how to do it then get a reputable shop to. The performance you get is worth the money. Oh, and I'd slap a Vortech on that thing in a heartbeat. Superchargers are not out of reach anymore, there are deals out there.
Yea, i was looking at vortechs last night after i posted this, and i want to go that way more and more - i already have the #30 lb injectors and the MAF to match - the only thing the kit does not look like it comes with is a new fuel rail, so ill have to pick up a larger one of those (idk if stock fuel rails would handle what the SC would need)
If gears wont cost me over $600 including parts and labor, than that is a good deal, but i really only want to do one or the other. Im afraid that if i put 3.73s or 3.55s in the rear, THEN decide i want the SC, i wont have the highway driving capability that i want
Any input is appreciated on the matter
The stock fuel rails are fine, in fact I've seen 500+HP cars with them. We are also running 30lb injectors right now with an FMU. We need to change this to 42's in the future but for now we'll wait until dyno day then make that call. The Vortech Kit will have everything included minus the fuel and ignition upgrades. It does come with an FMU (see blue disc bottom left in this pic) and 2 diaphrams. You may be able to find a blower kit used, that guy took a bath on a new one and in need of money. Gears work well with a blower, not so much with a Turbo. More RPM you can put into a centrifugal kit the better. So 3:55's or 3:73's will be fine. In fact I'd say gears are mandatory. On the way home from buying my 94GT from the Ford dealership I stopped into Steeda for a gear swap. It's the first mod to do in my book period. At highway speed say 70MPH the RPM's will be around 2000 with 3:55's. With 3:73's add another 200RPM, 4:10's another 200RPM, etc. Not exact but rule of thumb.
Now that is what im talking about - that is what i want my engine bay to look like! :nice::nice: So it looks like im already set with the fuel upgrades (getting the FMU and Fuel Pump w the kit i believe after reading vortechs website), so i would just need the ignition, and i already have an MSD 6AL waiting to go on, so that should be it for ignition...
You would need the kit, the one we have is the V3i, bigger fuel pump 255 or 340LPH, adjustable fuel regulator (dial in fuel pressure) and a day for installation. The MSD6AL will be great, match it with MSC Blast coil, Autolite 3923 Spark Plugs gapped at .030. Should be able to bolt on 65-96HP depending on what pulley you run. We are running a UPR 4" Plastic Power Pipe (see it running into the fender) with 90MM Mass Air Meter.
If you want to see our project from Day 1 when we bought the car until present day (installing full Team Z Suspension) you can view our Build Thread. There are a ton of pictures.
http://www.stangnet.com/mustang-forums/838909-were-back-new-project-build-thread.html
Video of idle.
VIDEO0008.mp4 video by jpjr50 - Photobucket
More pics of the blower.
Before the powerpipe, MAF in the corner with filter.
Ill be looking around and getting quotes for gears and what not, this will be my first upgrade, im thinking of 3.55's, i dont want to go to extreme if im planning on an SC in the near future -
You sold me VibrantRedGT - my end goal is to own 1986-1993 Ford Mustang 5.0L Supercharging Systems | Vortech Superchargers
the entry level 5-6 psi kit - 4FA218-010L
Im thinking with what I have to work with and what i want to do with it, this would be the best fit
well i called the best rear end shop in town, and they gave me an estimate of around $450 w parts and labor (also new bearings and other parts that need to be replaced due to old age)
I saw on summit racing some 3.55s from ford racing were only 149, but the shop is going to be using Youkon (somthing like that), becasue that is what they can warranty - and claim that if they do it, that i will never have to worry about my rear end again.
Since you are worrying about cost of a gear install, i'd steer clear of superchargers and turbo's, especially turbos. Both of those items turn your car into a money pit.
Get some twisted wedges or afr 165's (if your shortblock is newer) if you need more power.
Why do you have 30# injectors? They are way too much for what you have, probably make your car run worse not better.
Im worried about the money im going to be spending because gears are just gears, not actual horsepower (yes i know gears are a big part of acceleration), i just want to spend my money wisley and effeciently.
The 30# injectors and bigger MAF was bought the same time i bought the turbo - because that was the original route i was going to take, but i believe a turbo is a bigger money pit than an SC would be
But if u put a sc on the car it will take power from the motor to run it. Its old tech. Sure its had to get better but still takes power away vs turbo. Just my 2 cents.
I changed gears in over the road diesel trucks so its not the same as cars, but when my dad changed the gears in my car before I bought it back from him, he made it seem like it was cake. He changed them out 3 times and rebuilt the limited slip also. That was 4 years ago and its still going strong. It ended up with the 373's and I think thats a real good gear. at 70 its at around 2200 rpm.
gears do make a difference don't shoot it down so quick. I'm so glad I did my gear swap and got those tall stock gears out. If you are really worried about highway rpms then think 3:55 or even 3:27 but much better than stock. these cars should have come from the factory with them. It is a must do mod right next to SFCs in my book.
It's not a Mustang. But I had 4.10's installed in my 2004 Marauder. It was the best mod I had done. (besides the Eaton swap I did a few months ago) I payed $120 for Ford Racing gears, $30+ for an install kit and $300 for labor. And don't let anyone tell you a little bit of gear noise is normal. BS. Mine and countless others are as quiet as a mouse if done properly.
I'd say do the gears. Instant fun and a lot less $$$ than supercharging plus a dyno tune.
- Sent from my iPhone
Eaton Swap = Wreeeeeeeeeedom!!
Oh man, decisons decisions -
Me wanting the supercharger is just like a fat kit wanting to eat his whole dozen donuts
Gears are like bodybuilder eating a 32oz steak the night before a comp lift
So gears will be first, ill probibly end up with 3.73s, then work on saving for the supercharger
... But the donuts tates sooooooooooooooooo goooooooooooooood
