what to do with tranny cooler lines?
as someof you kno im swapping my car to a 5 speed. i was just wondering, what should i do about the cooling line from the AOD in the radiator? they are separate from the radiator correct? how should i go about capping the lines?
Don't remember the size offhand, but just go to home depot or ace hardware and buy 2 plugs, teflon tape them, and screw them in.
Not sure what to do about the lines themselves.. I would think they'd come off when you removed the old AOD.
It's probably not even necessary to plug the radiator -- but will make for it a little nicer in case you ever go back.
The lines can just be removed. They may need to be cut off, they look pretty well snaked in.
