  • 1994 - 1995 Specific Tech
What tool for header to H pipe studs?
  • Thread starter Thread starter CivicEater
  • Start date Start date Mar 21, 2004
C
CivicEater
579
  • Mar 21, 2004
What adapter or tool do I need for the header to Hpipe studs? I am putting the H-pipe back on and dont have the right tool I guess.. Thanks...by the way, I figured out the Dist. Prob (thanks Jason)
GTJake
3,049
Ann Arbor, MI
Mar 21, 2004
  • Mar 21, 2004
I just used some attachments that pivot and some extentions.
Jake
C
CivicEater
579
  • Mar 21, 2004
Jake
?? but if I screw with the center piece (the one that accepts wrenches) into the header then I cant screw the other end into the H pipe....
GTJake
3,049
Ann Arbor, MI
Mar 21, 2004
  • Mar 21, 2004
I guess I'm a little confused on what you're talking about...
Jake
randomjoker
427
Oklahoma
Mar 21, 2004
  • Mar 21, 2004
Jake
pictures always solve these problems.
C
CivicEater
579
  • Mar 21, 2004
My digi cam is in delaware with my momma picture a head stud.....((((D))))...( = THREADS and D = head of a normal bolt. (accepts the wrench).......so if I tighten into the header then I still have the other side of the D to screw into the hpipe......but I cant tighten the other way or I will undo the header connection.....lol mabye I need to ditch the studs and go get some normal bolts.....
GTJake
3,049
Ann Arbor, MI
Mar 21, 2004
  • Mar 21, 2004
Just get two nuts, tighten them together on the stud and screw the stud into the collector. Then break the two nuts apart and take them off. The stud should be sunk into the collector pretty far. Then put the h-pipe on and put the nuts on and tighten down.
Jake
C
CivicEater
579
  • Mar 21, 2004
Jake
Hey that sounds like it might work....I dont suppose you could draw me a goofy pic similar to the one I did, just so we are thinking the same thing......
mytight95
2,605
Dothan,Al
Mar 21, 2004
  • Mar 21, 2004
its basically called a jam nut, it keeps the single nut from turning so when you turn the srench/socket the stud turns instead of the nuts, when you get it threader throught the h-pipe flange, and into the headers threaded flange. then when you get the stud threaded through the h-pipe flange and into the header flange, remove one of the nuts and tighten down the one nut to pull the flanges together, it is easier with a bolt.
Got all that, LOL
jason
GTJake
3,049
Ann Arbor, MI
Mar 21, 2004
#10
  • Mar 21, 2004
  • #10
Here's a crude pic. Just tighten those two nuts until you can turn just the stud to the right. The stud will sink into the collector. Then just break the nuts apart. Take them off and attach the h-pipe.
EDIT: Couldn't get the pic to work.
Jake
L
laidback
#11
  • Mar 21, 2004
  • #11
I might be misunderstanding the post but the stud does not screw into the h-pipe if that's what you are asking. The stud screws into the header, then the h-pipe slides over the studs, then you put the nuts on the studs and pull the h-pipe up tight.
mytight95
2,605
Dothan,Al
Mar 21, 2004
#12
  • Mar 21, 2004
  • #12
well said.!!!!!!!!!!!
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
