Red_LX said:We need something a little more specific than "what transmission will work"...
you need a 5spd, unless you find a Turbo Coupe with an auto and swap both in. the only trannys that go with a 2.3T are the 5speeds or a built C4 and only big time drag racers put those in. if you want your current auto to go with the turbo motor you plan on putting in, then do it......... if you want your trans to blow up in less than a week.KurtPB said:i dont want a 5spd. i want to keep this auto in, which i'm assuming it's the a4ld or is it the c3? i dont know much about the code name crap for these so, meh.
Slow92LX said:im gonna tell you straight up. with the exception of the C4, Ford auto trannys are garbage. why do you want it to be auto so bad? do yourself the favor and swap a T5 in.
Red_LX said:Well I beg to differ, the C6 is about bulletproof, of course it won't really fit in a Mustang and definitely won't bolt up behind a 2.3.
will a c4 work?Slow92LX said:im gonna tell you straight up. with the exception of the C4, Ford auto trannys are garbage. why do you want it to be auto so bad? do yourself the favor and swap a T5 in.
