What type of a fitting
is used to connect a 3an braided hose (female end) to an oil gauge that originally used a tube, a ferrel, and a small nut? The oil gauge has a male end that is maybe half the diameter of a 1/8" NPT fitting. I need to adapt it up to at least 1/8" in order to make a connection.
I have some brass fittings that came in the kit, but alas, none of them are small enough (less than 1/8" NPT) to screw onto the back of the gauge. What gives?????
NPT FYI
FYI, just for info sake, ( I agree it's probably a 1/8 NPT) but there is a 1/16 NPT size. some of the NOS jets use this size. If you need fittings for the 1/16 NPT, you will probably need to check with McMaster Carr or other industrual supply house for the taps or fittings.
Thanks.
Yeah, I discovered that there is a 1/16" npt through google.
Unfortunately, after a little research, I discovered that the compression fitting used on the back of the gauge is a straight 5/16 x 24. There is no taper on either the back of the gauge or the fitting to make a firm, leak free connection.
I've done my McMaster Carr research and see nothing usable. At this point, I think I'm screwed in trying to connect this gauge. . . . . .
1/16NPT is 5/16" in diameter and has 27 threads per inch. My straight fitting is 5/16" in diameter and has 24 threads per inch. After looking around for a while, it looks like there are no conversion parts made to match them up. WTF up with that??????
So, I ended up making a 5/16 x 24 female to male 1/8" npt adapter on the lathe out of some brass. It uses a ferrel for sealing and a 1/2" long piece of 1/16" tubing to hold the ferrel straight while I tighten the the adapter to the back of the gauge.
I also built a test leak down test rig so I can check for leaks so I guess I've handled the problem the best that I can.
Thanks for all your help! :nice:
Nice job, you punished that :-)
