What type of tranny fluid do you use?
AirWolf87
382
L I, NY
Hey, The new tranny is in the stang (old one was beat to ****) and considering how hard it was to fork over all the cash (could have been better spent on pi heads :damnit: ) I want to make sure this one lasts. What type of tranny fluid do you guys use? any pointers on what i should look for in tranny fluid? btw its a 5 spd...thanx
I use Mobil 1 Synthetic ATF. When I retofitted one (from a newly wrecked '93 GT) into my '65 convert. 155,000 miles ago I started using it. I change it every year and the trans still shifts like new. The '01 GT convert. gets it now too.
Ok guys please help me. I have a 96GT 5-speed... how in the hell do I change the tranny fluid? I've looked all through the engine and I dont find anything for the tranny. Also is there a manual tranny fluid or is it ok to use automatic fluid?
Im such a n00b. :(
Im such a n00b. :(
The drain hole is pretty obvious on the bottom of the tranny. However you will have to find a way to get the new fluid up into the top of the tranny. It is quite cramped up there.
I used Mobil 1 ATF with a squeeze bulb hand pump from walmart. Found the pump in Walmart's auto section. The fluid should be pretty easy to find. Fill should be about 3.5-3.7 quarts.
