  • 1994 - 1995 Specific Tech
What Vacuum with cams.
  • Thread starter Thread starter MattZ281LE
  • Start date Start date Apr 20, 2006
MattZ281LE
345
Purcellville, Va
Apr 20, 2006
  • Apr 20, 2006
What kind of vacuum are guys running with cams and what mods. Whats your idle speed.
I am trying to get an idea on my cam.
My unknown cam idles at 8-9" at 900
- Matt
MattZ281LE
345
Purcellville, Va
Apr 20, 2006
  • Apr 20, 2006
Anyone
4Jenna
4,326
AZ
Apr 20, 2006
  • Apr 20, 2006
12" at 750rpm
331/T-trim
Cam Motion Custom Cam .542/.565 228.232 114lsa
Grn92LX
Fidanza Man!
6,819
64
129
New York
Apr 21, 2006
  • Apr 21, 2006
Appx 10" at a 900 ish rpm idle. Fairly healthy n/a FTI hydro roller
Joes95GT
3,132
Delaware
Apr 21, 2006
  • Apr 21, 2006
Trying to determine cam specs from vacuum readings is absolutely senseless. Duration, Lobe Separation and IC play factors in vacuum. Wide LSAs pull higher vacuum readings, and bigger durations can bring them down....it's the combination of everything....
Joe
MattZ281LE
345
Purcellville, Va
Apr 21, 2006
  • Apr 21, 2006
Not really looking for any specs. Curious about other combos characteristics and idle quality. My cam is very peaky. I am thinking of dumping it in favor of a custom.
If I wanted to know specific specs. I could use a dial indicator and degree wheel to get the duration and lift values.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 22, 2006
  • Apr 22, 2006
Your dyno graph does not look "peaky" but that is a personnal thing when judging against it's driveability - it would be fun to see a custom and a re-dyno.
zenboy99
2,212
Madison, WI
Apr 22, 2006
  • Apr 22, 2006
I'm pulling 13 at idle. High lift, short duration cam 111LSA
MattZ281LE
345
Purcellville, Va
Apr 22, 2006
  • Apr 22, 2006
Mainly I want to lower the RPM band. Torque is peaking at 5500 and HP has no sign of letting up. Yes it seems very linear on the graph.
It has OK driveability. Does not like being below 1500-1600 rpm. Low speed parking lots are a pain. It really comes alive at 3500 and gets stupid. But I think that is the blower.
I have to be QUICK shifting it at full throttle in 1st and 2nd. Rpms go from 2500-7000 is a split second.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 22, 2006
#10
  • Apr 22, 2006
  • #10
It's a beast - they might not drive well in parking lots Matt! Is this a race engine in a street car? I'll be the first to admit I'm not familair with your boost curve but it probably isn't much at low rpms and the induction system is set up for rpm - it's gonna be soft down low.
I think if you work with a good cam guy you will be able to tame the beast some if you have (can get your hands on) the specs of the cam that is in there when you work with your custom cam supplier.
best of luck to you Matt...........
gmkillr
606
Apr 22, 2006
#11
  • Apr 22, 2006
  • #11
Im pulling around 20" w/ the stock cam at an idle of 1200rpm
Zero Signal
2,633
Tucson, AZ
Apr 22, 2006
#12
  • Apr 22, 2006
  • #12
10-12" , .533 total lift, 218° duration @ .050, 110° LSA
4Jenna
4,326
AZ
Apr 23, 2006
#13
  • Apr 23, 2006
  • #13
idle@1200rpm and a stock cam...????
gmkillr
606
Apr 23, 2006
#14
  • Apr 23, 2006
  • #14
I set it that high cause my old battery could barely keep a charge at 700-800, but I now have an Optima yellowtop and just never turned it back down yet.
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
