What water pump?
  • Thread starter Thread starter 19stang66
  • Start date Start date Oct 15, 2005
19stang66
689
  • Oct 15, 2005
Well we came to the conclusion that my coolant leak is coming from the water pump. Its coming from underneath and its dripping straight down so my brother explained to me that there is a little hole in water pumps and when they go bad the hole will leak fluid. Is this true for all water pumps? Im going to NAPA tomorrow to get a new water pump and was wondering if I should save some money by getting a remanufactured pump or spend a little extra and get a new one. Also should I get one with a cast iron pump or an aluminum? Id like to get a less expensive one since I currently cannot get the employee discount from NAPA because Im not working until my fball season is over. Thanks.
5.0ina66
664
Ohio
Oct 15, 2005
  • Oct 15, 2005
Yes, it's called a weep hole. Honestly, I'd just buy a plain 'ol replacement waterpump; it shouldn't be over $25. Be careful, the factory aluminum waterpump for the HiPOs and the early 289s goes with a rare, expensive timing cover and won't fit without the matching timing cover, so don't buy one of those pumps.
HTH
--Kyle
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Oct 15, 2005
  • Oct 15, 2005
Hey wait, I had a '65 289 with a(hard to find) "parts store" aluminum water pump and it didnt need a different timing cover. It originally had an iron pump.
Just go to Napa like you plan, but take the old pump with you to match it. A new pump shouldnt be more than $5-10 more than a rebuilt, so I personally would opt for a new one. A ReMan will be just fine, though. More power to you if you can get it in aluminum.
66StangFastback
181
norman, oklahoma
Oct 15, 2005
  • Oct 15, 2005
I think at autozone they will give you some money for your old one (because they use them to be rebuilt) Might be the same with Napa? It's not a whole lot, something from like 4-6 dollars maybe, but every little bit helps.
19stang66
689
  • Oct 16, 2005
Ya NAPA does the core charge thing. Its only if you bought one originally from them and are bringing that same one back for a new one. Thanks
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
E
  • Sticky
2003 Mustang GT convertible water leak
  • Eightiesrock1980
  • Jul 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 28, 2026
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
