  • SVT Tech Forum
What went wrong?
  • Thread starter Thread starter cwd
  • Start date Start date May 3, 2005
cwd
38
laurinburg
May 3, 2005
  • May 3, 2005
Car died at 5k! Any ideas why? Suggestions appreciated!
T
TheDukeOfEarl
127
  • May 3, 2005
it died? Do you mean the drop off in torque? Your torque curve is nice and flat most of the way. Your HP continues to climb. I dont see any death here.
cwd
38
laurinburg
May 4, 2005
  • May 4, 2005
Yes the torque drop
Numbers were low overall for the mods I have in my opinion. I have changed the lower aux pulley position in case of belt slip. Man running the dyno said the car should keep making both numbers thru RPM range. No excuses but I was the first in after a thunderstorm came up and car was wet. I have the hood mod and front of engine was wet big time....pulley area etc.
T
TheDukeOfEarl
127
  • May 4, 2005
sorry but the torque curve will drop off. It doesnt keep going up with the HP. What mid pipe do you run?
cwd
38
laurinburg
May 5, 2005
  • May 5, 2005
Welded up locally
hickman Performance took stock mid pipes and cut them, welded on the extensions that came with the Bassani headers and fit the system together. No cats, still has baffles then Borla cat backs. There is a rather steep drop at the header bolt up location down then mid pipes level out> DO do you think this could be a problem? Thanks for the input!
T
TheDukeOfEarl
127
  • May 5, 2005
The exhaust is where I usually look for problems on heavy modded engines. Too many times I have seen all sorts of intake changes and no way for the burnt gasses to get out of the way.
cwd
38
laurinburg
May 6, 2005
  • May 6, 2005
I've got two choices
I will either but the Bassani mid-pipe to match headers or put a 50 shot dry kit on it. Which would you do?
T
TheDukeOfEarl
127
  • May 6, 2005
I dont like squeeze. Its way too hard on the engine. Add the mid pipe and see how things go. What exactly are you trying to get the car to do? At a point you have to wonder what its all for. Are you still using it on the streets or has it a dedicated car?
cwd
38
laurinburg
May 7, 2005
  • May 7, 2005
Not a dedicated driver car
I want a dyno of around 550 hp whatever it takes. I show the car and drive it too cruise ins, dyno days etc. A toy! LOL!! Did you note "no cats" on mid pipe/ baffles only? Thanks for the input...
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
M
Please help me identify this.
  • MattyB77
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 4, 2026
gkomo
  • SVT Tech Forum
