What will my set up run?
slayerripkdc
1,341
brewster ny
I have a 90 gt with the following mods, tell me if it is capable of running in the 13's with good street tires and good driving also what do you guys think the rear wheel horsepower and torque would be????
borla exaust
off road h pipe
short headers
Moroso cold air
65 mm throttle body
73 mm c and l mass air meter
24 lb injectors
trick flow street mannifold
underdrive pullies
373s gears
14 degree timing
short belt minus the air pump
I dont have street tires, but have a very close set up (you have mass air and injectors over me) and ran a 13.0 @ 103. I think on street tires I could have pulled a 13.4-13.6 at 102-104, so I would say you have a good chance at the 13s. Just drive it like you stole it!
what brand street tires do you have? i was able to cut 1.99 60fts with my setup and 245/50 BFG KDW's. it got me in the 13.90's. alot of it is driving rather than how much power your car has. with street tires, launching will be difficult. your best bet would be to keep the rpms up in the 1200-1500 range feather the clutch outa the hole and ease into full throttle, then go from there. i dunno if u speed shift, powershift, or granny shift, but i gained ~ .1 by powershifting. u should be able click off some consistent 13.6s with street tires id say.
