what wire for sheet metal?
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
I have a lincoln wire feed, and i want to patch the floor pans on my truck.
I will be cutting out the rusted metal and patching it with some sheet metal that I already have. Just need to cut to fit. i will lap weld it and grind it smooth.
What type of wire do I need to buy to do this? i will be heading north to a bigger city today in search of it.
I have used about 12lbs. of .030 wire on my 66 fastback. A lot of rust repair but i also welded up a lot of areas like around the torque boxes in the rear. It seems to do the job pretty well. Good luck.
The smallest wire I could find when I was doing my floors and quarters was .023" solid steel wire. You do not want flux core wire unless you do not have the ability to run gas. There is a huge difference when welding thin metal using .023" and .030" wire.
hungrymonkey said:
I do not have gas on it.
Then go with the smallest flux core that you can find, which is probably .030. I've done body work with .035 fluxed, but it took a while to master. By the time I finished doing a radiator support, battery apron, floor pans, a cowl vent, 2 quarters, trunk floor, and a tailight panel, I was quite proficient. As always, make sure the welding surfaces are clean.
Want to see me doing it with my Lincoln flux core??? :-) http://www.geocities.com/dennis_2685/Newcoupe.html
That said, I must say that a true mig works much better than the flux core. I prefer borrowing one when I have some serious welding to do.
if you can get hooked up with gas, i recommend using ER70S-6 solid core wire, .023 if it is a 110v or .035 if it is a 220v welder..... it will be a huge difference in welding. the solid core is way better suited for bodywork. if you know your welding, you will also know what the ER70S-6 is, it is the industry standard in autobody repairs. welding with flux core wire will be frustrating while doing this work. good luck either way!
