what would be a better super charger
jdetten said:
i was going to get a coba killer kit but what one is better vortech or novi 2000
Well, knowing what kind of work Cobra Killer does, and how good he is at what he does i would say you cant go wrong either one
I have the Novi 2000 currently. The main difference is the Novi will be capable of pushing more boost in the end than the Vortech. Also, the bracketry is much, much better than the Vortech.
NOVI-2000
The original NOVI-2000 is the centrifugal supercharger that revolutionized the supercharger industry in 1995, and remains Paxton Automotive's most popular supercharger today. Though the NOVI's unique impeller design and compact scroll housing make it capable of producing 27 psi of boost and sustaining 900+ horsepower, most Paxton Automotive NOVI-2000 systems are designed to deliver 8 psi of boost. This moderate boost level delivers maximum power and torque, yet is safe for today's engines running on 91 octane or better unleaded pump gasoline. A horsepower gain of up to 50% on most big and small block V8 engines is typical without a loss of fuel economy in cruise situations.
CFM 1700
Max Horsepower 980
VORTECH V-1 T-TRIM SUPERCHARGER
The supercharger of choice for street/strip vehicles with modified engines
Straight cut spur gear
Fits engines up to 825 horsepower
Maximum airflow: 1,200 CFM *
Max psi: 26#
Hope that helps!
Bo
@ the same psi i would thik there wouldnt be, cuz arent they the same type of supercharger? centrifugal (sp?) now if u did the KB @ the same psi as the superchargers tested, i bet u would see a difference :)
