Wow, this thread received a lot of play...
Ok this is what I got from all the responses..
1. Check Fuel pressure at 5000+ RPM
2. Test Coil / try another one perhaps. Currently using a 10 year old Mallary.
3. No Rev Limiter, running an MSD Ready To Run Distributor. (no Box)
4. Spark plugs, running what was installed at the time I received the motor, new of course, once a year.
5. Fuel Pump voltage should be OK, using the correct feed from Ron Frances
6. Motor Temp, I usually run between 185 and 190, not an issue.
7. Octane, I usually only run 89 because I again usually only just cruise around, but I can try 93 or 94 and see if that makes a difference.
8. Spark plugs look good, I will heck the gap.
9 Wires are new, 2 years old, MSD.
10. Alternator charging at 14 volts.
As far as how the motor is built I am going to assume that nothing engine wise needs to be looked at.
I also did call "The Engine Factory" They also mentioned everything you guys suggested.
Ok give me some time and I'll post my results.
Thanks.
Peter S.
Thanks.
Peter S.
