  • 1994 - 1995 Specific Tech
What would cause this.
  • Thread starter Thread starter WhiteDevil
  • Start date Start date Mar 21, 2004
WhiteDevil
2,717
San Diego
Mar 21, 2004
  • Mar 21, 2004
So i installed my new AFM N/A Power pipe and Pro-M 80mm MAF on my GT last week. and i drove it a few times. It idles fine and runs great, and it pulls really hard to 5,200 then it like pings/breaks up right past 5,200. Sometimes worse than other times. It didnt do it however the first few times that i drove the car. But it just randomly started. Sorry to be so broad, any ideas.
95snoozer
2,572
RCR
Mar 21, 2004
  • Mar 21, 2004
if it was programmed for 24s it might do that ... just a though
how hot is your car?
or bad tank of gas... stay off it till you get some premium form a different place
WhiteDevil
2,717
San Diego
Mar 21, 2004
  • Mar 21, 2004
The calibration card with it says #19 so im ruling that out for now. The car runs nice and cool its got a 180 stat and Fluidyne. I was thinkin it could be the gas too, ill probably try some new gas from a different place.
GTJake
3,049
Ann Arbor, MI
Mar 22, 2004
  • Mar 22, 2004
Are you running 91 or 93? I would say it's bad gas also if it started doing it recently and not right when the meter went on. Also, the power pipe probably flows better than that MAC unit you had, so that may cause a lean condition in the upper RPMs. Maybe try bumping up the FP a little bit.
Jake
9
94whitesnake
152
Allentown, PA
Mar 22, 2004
  • Mar 22, 2004
i'm no pro, but it sounds indicitive of the MAF actually maxing out way before it should? Doesnt make sense with the mods he has, but I'm just throwing it out there. It would suck if that's the case.
WhiteDevil
2,717
San Diego
Mar 22, 2004
  • Mar 22, 2004
Well i use 91 octane. The gas in the tank is about a 3 weeks old because i havent been driving the stang that often. Im not sure how much that could effect the quality of the gas? When i put the new CAI and MAF on it ran good and pretty strong. Then i didnt drive it for a week or so and then i came back and it was doing this. Well here are the steps im gonna take and the order.
1st Fill the tank with new premium Gas
2nd Tune up Plugs, wires, fuel filter
3rd play with fuel pressure
4th play with timing
How does that sound anything else i should do?
95snoozer
2,572
RCR
Mar 22, 2004
  • Mar 22, 2004
i had a brain fart
THE MAF IS NOT READ AT WOT
play with FP timing and gasoline and keep that radio off to listen to Detonation
9
94whitesnake
152
Allentown, PA
Mar 22, 2004
  • Mar 22, 2004
95snoozer said:
i had a brain fart
Thanks, I did not know that. I guess that's why it's called "closed loop". Sorry everybody.
95snoozer
2,572
RCR
Mar 22, 2004
  • Mar 22, 2004
i myself forgot until It clicked in my mind
WhiteDevil
2,717
San Diego
Mar 22, 2004
#10
  • Mar 22, 2004
  • #10
Really? The Maf isnt read at WOT??
baglock1
The Bartender
6,612
Space Coast, FL
Mar 22, 2004
#11
  • Mar 22, 2004
  • #11
At WOT the EEC goes into closed-loop mode. Basically, it disregards any readings from most of the sensors. The MAF, O2's, etc. It sees the WOT and just starts dumping as much fuel as possible into the engine to prevent any lean condition and to piss off the EPA.
swingline
1,252
TCB - Taking Care of Business
Mar 22, 2004
#12
  • Mar 22, 2004
  • #12
to piss off the EPA
My O/R H-pipe's goal in life.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
