WHAT!!!
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date Aug 10, 2006
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Aug 10, 2006
  • Aug 10, 2006
Hey guys I just of last friday got an 86 gt with a 93 motor and tranz in it. Anyway, it has a battery relocation kit in the trunk and well it got tipped over (yeah I havent got it strapped down yet!!). So after cleaning all that crap up, I freakin put the positive cable on the negative and vice versa , long story short, it wont start, and none of the lights come on!
I looked at the fuses and one of the 30watt fuses was blown, but thats all I can find, we tried to jump the car, and the starter didnt click, so I think that the starter solenoid is smoked, any other suggestions?
Thanks, josh
dastang2
2,020
tx
Aug 10, 2006
  • Aug 10, 2006
it is your fusable links. they come off of the solinoid on the hot size. you will see some orange rubber things on the wire. i need to cut them out and put in the right size fuses in place. this is your problem.
1991vert
1,103
Ludlow, MA
Aug 10, 2006
  • Aug 10, 2006
r
o
f
l
sorry, but that was a careless mistake. you could have fried the ECU...
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 10, 2006
  • Aug 10, 2006
The thing is the lights dont come on, nothing comes on, except the fuel pump cuz it has a separate switch, Im leaning towards a ignition switch now but I am still confused.
Josh
dastang2
2,020
tx
Aug 10, 2006
  • Aug 10, 2006
trust me, check the fusable links. you will find the problem. cut them off and run a jumper wire to the power and watch your lights come back on. do that just to test it.
dastang2
2,020
tx
Aug 10, 2006
  • Aug 10, 2006
the igntion switch has nothing to do with lights. it's the fusable links. i have seen it many times.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 10, 2006
  • Aug 10, 2006
Where exactly are the fuseable links? Are they by the brake booster, and the diagnostic ports?
Thanks for the info :dastang2
Josh
Mustang78
486
Aberdeen, WA
Aug 10, 2006
  • Aug 10, 2006
he already told you where the links were "it is your fusable links. they come off of the solinoid on the hot size. you will see some orange rubber things on the wire. i need to cut them out and put in the right size fuses in place. this is your problem." look by the battery!! they're a large wire with a big plastic cover looking thing over part of the wire..you'll see just look around
~Mark~
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 10, 2006
  • Aug 10, 2006
Ite, that what I was thinking. My batt is in the hatch, just to let ya know.
Josh
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Aug 10, 2006
#10
  • Aug 10, 2006
  • #10
hey I checked out some of the "fusible links", and they are blown from what I see, melted ends, so that cant be good. Thanks for all the advice!
Josh
dastang2
2,020
tx
Aug 11, 2006
#11
  • Aug 11, 2006
  • #11
you can shave the top of the rubber off to verify that the wire inside is burned. but i am 100 percent sure that if you just put in some fuses in place, it will work. make sure you replace all of them. one is for your charging system, 0ne is for the ecu and one for your lights i believe.
A
No power
  • Artyom
  • May 14, 2024
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 15, 2024
Mcmahst
H
70 fastback: Good battery, but nothing happens.
  • hankmeister
  • Mar 4, 2024
2K
1965 - 1973 Classic Mustangs -General/Talk- Mar 21, 2024
hankmeister
H
1991 5.0 slow starting
  • bad_decision
  • Jan 8, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 8, 2023
General karthief
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
2004 Mach1 A/C
  • SMOKEDYA
  • Jul 22, 2023
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 22, 2023
SMOKEDYA
