Fox Whats A Good Size Alternator To Buy?
  • Thread starter Thread starter James V
  • Start date Start date May 5, 2017
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
May 5, 2017
  • May 5, 2017
Found out the current stock alternator (75 amp) will barely give enough power to run the electric fans. (as I'm sure most of you know the stock alternator is pretty bad) What would be a good size to replace it with? I saw a kit with a 160 amp on LMR.
Mustang5L5
Mod Dude
Feb 18, 2001
43,260
17,945
224
Massachusetts
May 5, 2017
  • May 5, 2017
110-130 is all the standard typical bolt on fox body needs unless you have a competition grade stereo system.
Start doing things like multiple fuel pumps, electronic water pump, etc and then you can consider going higher
Reactions: Shakerhood
Bullitt347
I have been doing it wrong this whole time
3,975
2,958
194
Middle of Maine
May 5, 2017
  • May 5, 2017
I run a 200 amp alt in my car, uses stock brackets.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 5, 2017
  • May 5, 2017
Here's a map for your journey...
Electric fan = 3G alternator if you want long life & reliability from your car.
The electric fan saves some HP. The stock fan's parasitic drag runs from 7-12 HP depending on who you talk to. The electric fan uses about 1/2 HP of power from the electrical system.
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
Rear window defroster = 5 amps
That's grand total of 79 amps from a 65 amp alternator. Talk about overdrawn at the bank!
If you aren't going to waste money on a super stereo system on a car that has loud exhaust, the 130 amp 3G or 6G alternator is a very good choice. There is enough power to run all the stock electrical equipment and electric fan with no problems.
Reactions: Shakerhood and James V
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
May 5, 2017
  • May 5, 2017
I want to start doing more mods and HP adders eventually, should I get a higher amp alternator now?
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
May 5, 2017
  • May 5, 2017
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 5, 2017
  • May 5, 2017
any 94-99 3G alternator from a Mustang will work
Reactions: James V
Bullitt347
3,975
2,958
194
Middle of Maine
May 5, 2017
  • May 5, 2017
You have to add up the amp draw of all your accessories that consume power and then go about 20% larger than that. In my case I have 2 electric smog pumps used as an crankcase EVAC system, one electric cooling fan, electric water pump, FAST XFI ecu, Aeromotive Eliminator fuel pump, Rule I/C water pump, Boost controller, Bosch water pump for supercharger, trans brake solenoid, line lock solenoid, MSD ignition system and oh, yeah, the headlight and tail lights if needed along with power windows. So, yeah, 200 AMP 3G ALT.
Reactions: James V
a91what
SendMeUrDataLog
10,739
6,721
214
Hillsborough county
May 5, 2017
  • May 5, 2017
250amp 3g alt. 3000watt stereo and usual powered goodies.
Davedacarpainter
Nov 28, 2015
11,833
11,633
203
Discordia
May 5, 2017
#10
  • May 5, 2017
  • #10
Please don't take this as an insult.....WOW!
Mustang5L5
Mod Dude
Feb 18, 2001
43,260
17,945
224
Massachusetts
May 5, 2017
#11
  • May 5, 2017
  • #11
All depends on what you do. If you just add an Efan, all you need is a 3G/6G 130 amp oem alt. If you start building the starship enterprise and need power for all sorts of things like Bullitt347, then you can go with a bigger alt. But for most fox mustangs, 130 is plenty
Reactions: Bullitt347 and James V
Bullitt347
3,975
2,958
194
Middle of Maine
May 6, 2017
#12
  • May 6, 2017
  • #12
Hmmm, Starship Enterprise....I like it! Could someone point out to me where engineering is located cause I have yet to reach warp speed...
Davedacarpainter
Nov 28, 2015
11,833
11,633
203
Discordia
May 6, 2017
#13
  • May 6, 2017
  • #13
That'll take that larger dilithium crystal spec alternator.....I think it's rated at 14 bagillion watts. You'll need a different sized pulley.
Reactions: a91what and jrichker
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
Electrical Inaccessible starter solenoid from wire tuck, what are my options for an alternator upgrade?
  • AnthonyA1234
  • Jan 16, 2025
Fox 5.0 Mustang Tech Feb 8, 2025
Mindseye007
  • dan50
  • Jul 18, 2026
dan50
