What's a good strong non-smelling engine degreaser?
Mustang5L5
Mod Dude
Feb 18, 2001
43,250
17,934
224
Massachusetts
I need to clean my engine up a bit...mostly the lower end and aluminum components. Last time i did it i used the Gunk stuff in the orange can. It did an awesome job as i basically sprayed it on and all the dirt and grime just flowed away....however it had a STRONG aftersmell that wouldn't go away for weeks.
Simple green is too weak.
Any suggestions?
Simple green is strong...but that GUNK Engine degreaser is just MUCH stronger. When i do oil changes i spray the underside of the engine when done and the oil and grease just POURS off.
Downside is it has a strong aftersmell that you smell when the engine gets hot. Luckly doing just the undercarriage doesn't make it smell, but if you do the top end it tends to come in the vents with the A/C on and STINK.
I'm looking for something that will clean up the aluminum on the engine. I don't mind scrubbing..that's assumed, but just want something strong that won't smell when i turn the A/C on.
CD2.
I ended up using simply green concentrated. it did a good job. I got in there and scrubbed and my engine actually looks bright and new again.
Might pick up some CD2 next
Purple power works wonders! Just becareful not to let it sit on paint and plastic. Can stain it and you will have to buff it off.
Any pics of your 2003? Interested . . .
