whats a pip?
royster5point0
18
so my car runs great but only for about 20 to 30 min and then it shuts of, or when i shut if off after running for 20 to 30 min it wont start back up. i got some advice here and tested my tfi it was bad so i changed it. it seems to run a little longer before it shuts off but still has the same problem. i was told the pip works the same; runs fine till it heats up then stops working untill it cools down. either way i need to change it but i dont know the full name so its hard to look for prices. i know its inside the distributer and i think its the metal piece under the coil. but thats about all i know. any help is good. thanks
Profile Ignition Pickup, in advance auto computer i think its called the ignition pickup and its like 26 bucks im pretty sure. In order to change it, you will need to press off the distributor gear. That is if the PIP is your problem.
reman distributor will be easier to change .....
i have changed the tfi already and dont know what else it could be. is there a way to make shure? and 26 bucks is looking alright a new distibutor is a little more. i think. you wouldnt happen to have an msd sitting around would you?
Here is something I mentioned on your other thread. Since you never asked for more info on that thread, I assumed you understood.
"Now if you are missing spark AND injector pulsing (check the latter with a noid light - parts stores sell them for 5 bucks), the PIP is where to look. It is inside the dizzy's bowl."
A bad PIP will leave you with no spark and no injector pulsing (when the car acts up). If you have neither, the PIP is where to look. If you have one or the other, it should not be the PIP.
Good luck.
