Hey guys.... Looks like I need to add to my Zex tutorial for some of these questions.
I use the Dry kit because that is what was available when I bought mine.
Personally would go for their new wet kit now. To make sure my car doesn't detonate I have to run 43 psi on 91 octane gas and 6* timing.
My car shows a rich condition and the CEL light will randomly come on. To make it stop I drop my fuel pressure to 39 psi. The new wet kit would solve this problem as the Zex kit can only bump your fuel pressure so much from the idle setting. Which BTW - it took it to 80+ on the dyno!!!
The thing you need to think about is what size of shot do you want to use? I ran the 75 shot about 6 months. When I tried the 100 shot, that lasted a few months, before I went to the 125 shot. I wouldn't spray above 100shot with the stock setup. I could tell my car needed the bigger fuel pump and adj. regulator no matter where I put my timing.
My car has 165k miles on it and I'm embarrassed to count the numbers of bottles I've gone through. I was buying 2 bottles a week for a while.
The stuff is definately crack for your car. Very addictive.
One question is, how easy is the kit to "hide" -- No offense to the guys out there with the STEALTH kits.... I've been around juice enough over the past 2 years to confidently tell if someone has used it. No need to look under the hood.
One whiff as the car screams across the finish line and you can tell it's there. It's worse without cats... but you can smell it on my car with cats and full exhaust emisions. So if you can only hide it when you are NOT using it Why bother with relocating things and covering the hoses in black tape, and so on?
They call it torque in a bottle for a reason. It's really hard to get THAT much torque out of any other power adder that doesn't "scream" look at me under your hood. Such as a turbo or supercharger. You can't hide those very well either. LOL
My car will be back on the road in 2 weeks. I'll be making some videos when it is.... on and off the bottle. Plus I'll do a run down of where and how I hooked it all up.
