2002BLGT
Well-Known Member
TeknoMage said:It's easy as hell.
I nailed it on the first try.
It kicked out the @$$ end when I hit 3rd, and that was on a 03 GT with only a Tri-Ax. (no other mods)
now go blow the doors off somebody that cant drive
Snarf said:Simply, Powershifting = shifting with ZERO clutch.
Not a very good idea imo, but alot of guys do it. Prolly alot of the same guys who have trashed 3650s, hehe.
Im never in such a hurry as to not use the clutch.. 186K mi on my original plates![]()
StngStr said:Nope. Wrong man. Powershifting is holding the gas pedal to the floor, stabbing the clutch (in-out<--as fast as you can) and ripping the shifter into the new gear as you stab the clutch. It's basically popping the clutch just super super fast. You've gotta make sure you do it fast enough, otherwise you'll hit the rev limiter. If you have 186k mi on your original clutch plates then you've never correctly powershifted. I don't powershift first to second because I'll just spin, but I do from 2nd to 3rd at the track. I've missed a few times and it just bounces off the rev limiter and makes me look really stupid.
2002BLGT said:powershifting , helpful hint on how to do it right , old school style , when you start to take off in first , do this , grab the shifter while you have the pedal floored , if you have a decent clutch it shouldnt come out of gear as long as you are HARD on the throttle , pull back like you are trying to rip it out of the floor , when you get the revs about 200 to 500 rpms from where you wanna shift , stomp on the clutch pedal has hard and as fast as you can without letting off the gas , keep the gas DOWN , snap the clutch in and out bam bam , dont hesitate with it or you will MISS , your pulling back will pull it into second without even thinking about it , if none of you have been doing this try it tomorrow and let me know how it works for you , some people can do it some cant , seems to be a thing that just comes to you . Do third gear the same way but be very very careful , if you arent sure about your skills dont do it , ive seen to many people that thought they could drive a car slam one back into first , done it myself when i was mad at my girl , isnt good on the car , just push up and over to third while you are accelerating thru second gear , same process , 200 to 500 rpms shy of shift point , BAM in and out with the clutch pedal as fast as you can smack it down with your foot let off , some people side step it sometimes called , they kick it down and slide their foot off the left side of the pedal to make it even quicker , dont do this until you got the basics down of proper power shifting , alot of the older guys wont tell the younger guys how to do this properly because it does give you an edge if the other guy granny shifts or just shifts fast . do fourth the same way , hopefully by then you are smoking the other guy . and DONT LET OFF THE GAS
Good luck
