Check fuel pump duty cycle
Check pressure drop accross injectors
Check injector duty cycle
You NEED to datalog WOT to see if your pumps are maxing out...its unlikely that they are done at just part throttle. Just run to about 4 PSI and check the results and report back. I can compare them with my car @ around 4PSI and see at a given fual rail pressure and injector duty cycle, how much fuel will be actually going into the motor.
your best bet for teh WOT run is to pull 4 * of timing from the 2000-4000 and 6*s from the 4000-8000RPM ranges...your car will be a dog, but it will be rediculously safe....even with a really lean A/F. Just dont rev it enough to get over 4 PSI and you will be fine.
we have been selling Pro Racer training videos that show you, in the software exactly how and what to datalog and then how to apply this to the tune - there are over 10 hours of training on each disk - 5 for each version of SCT's Advantage software. We have sold a ton of them and one comment I keep hearing is that SCT should have included it with the software. We include it for free when we sell the PRP software and hardware to someone and discount it when someone gets just the software from us. See link in sig for more info.
