I have several here in front of me...2 in peices and one that was together. The two that are apart have what I belive to be (and is called in a manual) a shim. Now my question is when to shim, why to shim and such. Also, back to gear lube, I was under the assumption that you used normal gear lube with an additive. Someone else has said, you can only use limited slip gear lube. Whats the answer there?
(as par normal...the book just says that and then says you should not mess with it.....)
