whats wrong with my car???
  • Thread starter Thread starter riceslayer302
  • Start date Start date Oct 3, 2006
riceslayer302
Banned
Oct 3, 2006
CT
Oct 3, 2006
  • Oct 3, 2006
im new to the site but i know you guys really know your stuff so if you could help me please put in ur two cents
so it begins... ok, as some of you know i have been saving all summer long to buy this 1990 GT. i put 2500 down on it after test driving it this summer. when i drove it the car was perfect, it ran strong, had a couple mods but was mostly stock, i loved it and had to have it.
so yesterday i go to give the owner the last 2500 but decided to take it for a drive to show off the new car to my girlfriend. so i start up the car, let it idle for a minute or two and off we go. the car drives fine till about two miles down the road it sputters and bogs when i put my foot on the gas. so i swore and yelled and promised to kill the guy blah blah blah... so i pull over and pop the hood, there is a dry rot crack in the rubber grommet on the cold air intake. so i called the guy and we replaced the grommet... still nothing... i unplugged the mass air, nothing, unplugged tps, nothing. i even had my friend andy bring his mass air meter and plugged that in... nothing. no intake or vacuum leak that i can see...
the only way i can get the car to start is to block the throttle body with my hand and it only runs for a few seconds. i'm confused ive never seen this before...
the guy was cool though he had it towed and his garage is looking into it, he called me and told me the mass air was bad and they were replacing it... but as i said before i swapped it with my friend's... any advice anybody can give me? i am stuck between a rock and a hard place here... either way should i back out or talk him down??? the guy seems like a really honest guy to me... i just want my car...
2000xp8
SN Certified Technician
Aug 8, 2003
8,078
1,659
194
NJ
Oct 3, 2006
  • Oct 3, 2006
Could really be alot of things, but i wouldn't be too worried. As long as it's not: The trans, engine bearings, blown head gasket, or bad rear, no other problem on these cars is a big deal.
And your problems sounds like none of the above.
Meter doesn't seem to be a far fetched idea. Just slapping a new meter on like you did, may not give the car time to adjust to it.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Oct 3, 2006
  • Oct 3, 2006
just wait and see if he gets it fixed. sounds like he is willing to help you out and maby felt kinda bad.
riceslayer302
Banned
Oct 3, 2006
CT
Oct 3, 2006
  • Oct 3, 2006
i didnt reset the computer after putting the new sensor on... idk... its a beautiful car i love it... its just im going to college for HVAC and in a year when i am making 20 an hour as a hvac technician as opposed to 9 an hour at mustangs unlimited in manchester ct... i wanted to use it as a nice driver till i have enough money to put a aftermarket block in it and hopefully eventually a turbo kit.
ANY ADVICE IS WELCOME GUYS PLEASE HELP ME OUT HERE
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 4, 2006
  • Oct 4, 2006
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
riceslayer302
Banned
Oct 3, 2006
CT
Oct 4, 2006
  • Oct 4, 2006
i have one of those akron code readers i'll see what it says.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
