whats wrong with my car???
riceslayer302
Banned
Oct 3, 2006
CT
im new to the site but i know you guys really know your stuff so if you could help me please put in ur two cents
so it begins... ok, as some of you know i have been saving all summer long to buy this 1990 GT. i put 2500 down on it after test driving it this summer. when i drove it the car was perfect, it ran strong, had a couple mods but was mostly stock, i loved it and had to have it.
so yesterday i go to give the owner the last 2500 but decided to take it for a drive to show off the new car to my girlfriend. so i start up the car, let it idle for a minute or two and off we go. the car drives fine till about two miles down the road it sputters and bogs when i put my foot on the gas. so i swore and yelled and promised to kill the guy blah blah blah... so i pull over and pop the hood, there is a dry rot crack in the rubber grommet on the cold air intake. so i called the guy and we replaced the grommet... still nothing... i unplugged the mass air, nothing, unplugged tps, nothing. i even had my friend andy bring his mass air meter and plugged that in... nothing. no intake or vacuum leak that i can see...
the only way i can get the car to start is to block the throttle body with my hand and it only runs for a few seconds. i'm confused ive never seen this before...
the guy was cool though he had it towed and his garage is looking into it, he called me and told me the mass air was bad and they were replacing it... but as i said before i swapped it with my friend's... any advice anybody can give me? i am stuck between a rock and a hard place here... either way should i back out or talk him down??? the guy seems like a really honest guy to me... i just want my car...
Could really be alot of things, but i wouldn't be too worried. As long as it's not: The trans, engine bearings, blown head gasket, or bad rear, no other problem on these cars is a big deal.
And your problems sounds like none of the above.
Meter doesn't seem to be a far fetched idea. Just slapping a new meter on like you did, may not give the car time to adjust to it.
i didnt reset the computer after putting the new sensor on... idk... its a beautiful car i love it... its just im going to college for HVAC and in a year when i am making 20 an hour as a hvac technician as opposed to 9 an hour at mustangs unlimited in manchester ct... i wanted to use it as a nice driver till i have enough money to put a aftermarket block in it and hopefully eventually a turbo kit.
ANY ADVICE IS WELCOME GUYS PLEASE HELP ME OUT HERE
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
Codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Wal-Mart may now have the LCD display scanner for less than $35
