wheel bearings
noslow1986
274
oswego Il
how do u know when u have a bad wheel bearing. something is squeaking on the front driver side tire. the shop told me a wheel bearing. the noise goes away when i start to stop at a light or something or slow down
If your running the 87-93 stock style spindle a bearing is $12 and takes about 20 min. to change. If you are running 94-95 spindles its about $80.
Check your front u-joint as well. Sometimes they squeak as they go bad and the origin or the squeak is hard to narrow down due to it only squeaking while moving.
