Wheel Hoping
  • Thread starter Thread starter FoxRod87
  • Start date Start date Mar 22, 2006
FoxRod87
243
Carolina
Mar 22, 2006
  • Mar 22, 2006
When I spin the tires it wants to wheel hop. Woundering if anyone knew what I needed to do to get rid of this. Thanks.
blackcloud50
388
  • Mar 22, 2006
First..a good set of rear lower control arms. Wheel hop is dependent on a number of factors such as tires, temperature out, etc.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Mar 22, 2006
  • Mar 22, 2006
i agree with upper and lower aftermarket rear control arms. this will usally get rid of all wheel hop. i bought lakewood uppers and lowers and have 0 wheel hop.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 22, 2006
  • Mar 22, 2006
If there is some reason you removed your Quad Shocks, put them back on! Also your Quads may be worn out, you can get a new pair of Motorcraft Quads from PPI for a reasonable price!
06stangtyme
21
Nashville
Apr 1, 2006
  • Apr 1, 2006
Replacing the stock shocks should take care of the hop.
stock shocks are weak...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 1, 2006
  • Apr 1, 2006
Make sure the quad shocks are still in place, the previous owner may have removed them. Without some expensive lower control arms you will have wheel hop. The quad shocks mount on top of the rear axle and connect horizontally to the chassis . They are much less expensive than a good pair of lower control arms. The auto parts store near you should be able to fix you up for less than $20 a side. A trip to the J/Y will have you fixed up for about $5 a side.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
